Author: Subject: Dash battery light. Where does wire connect to on a bec?
Jason Fletcher
posted on 31/3/08 at 04:25 PM Reply With Quote
The dash has a battery ignition light. You know the one that comes on with the ignition key but goes off when the engine is running and the battery is charging. But where does it connect to on a Busa loom?
cheers
Jason
[Edited on 31/3/08 by Jason Fletcher]
posted on 31/3/08 at 06:12 PM Reply With Quote
Does the 'Busa definately have an ignition light? Not all bikes do- best thing would be to get hold of a wiring diagram...
roadrunner
posted on 31/3/08 at 06:46 PM Reply With Quote
Sorry to nip in ,but i have a similar question, my charge light is on the old pinto loom, now i have a bike loom to run the engine only, does this mean the charge light is redundant.
Brad.
Jason Fletcher
posted on 31/3/08 at 08:23 PM Reply With Quote
I am sure there was red ignition lights on the bike when I turned the key on and before engine started but can't be 100% certain.
Jason
minitici
posted on 31/3/08 at 08:53 PM Reply With Quote
Most bikes show an oil pressure light rather than an ingition light.
Jason Fletcher
posted on 31/3/08 at 09:50 PM Reply With Quote
ah yes I recon you might be right there.. maybe thats what I was seeing.
there must be a way to wire the thing in.
J
