eznfrank
| posted on 8/4/08 at 08:33 PM |
Did someone in here make a cable gear shift for a BEC??
If so could someone point me in the right direction as I can't find it again. Anyone have thoughts on this or know of a better solution as the
linkage MK made me is simply not going to work.
ChrisS
| posted on 8/4/08 at 08:41 PM |
Hi
Ive done a cable change. It works very well actually. Cant remember where i got the cable, but ill ask my mate who's also doing the same as he
got the cable. Cable cost about £40, and the brackets and lever i made myself.
Its a push pull single cable linked to a gear lever shift. One end has an m5 clevis and the other end i have an m5/m6 connector that goes straight
onto the R1 gearbox lever arm.
Not sure if any of my pics show what ive done but ill put up some pics in the next few days.
[Edited on 8/4/08 by ChrisS]
jacko
| posted on 8/4/08 at 08:45 PM |
Hellfire Team
eznfrank
| posted on 8/4/08 at 08:46 PM |
Cheers mate, is there much play on the gear lever?
Re: above, I think Hellfire's is same as mine unless they changed it since the re-build?
[Edited on 8/4/08 by eznfrank]
Guinness
| posted on 8/4/08 at 08:50 PM |
I have a cable gear shift on mine. Used a Teleflex or Morse control cable, from a yacht chandlers. They use them to turn outboard motors and have M4
or M5 threads on both ends. Then I made up a keyhole bracket for the cable to fix to, bolted that to the chassis, and then connected one end to the
bike gear lever (cut down a little) and the other to a lever welded up from a bit of steel and a L shaped bracket. All connected up using tiny rose
joints.
Works well!
HTH
Mike
eznfrank
| posted on 8/4/08 at 09:01 PM |
Do you have any photos by any chance?
airframefixer
| posted on 8/4/08 at 09:05 PM |
Cable shifter on mine, not a seven. 1/4-28 thread on either end to rod ends. Cost was $36 CDN, maybe the same as the boat motor one described. The
mounting plate is 1/8 steel, it flexes slightly, Ill fix that with either a longer gusset or a doubler. the stroke of the cable is 3 inches, it only
needs about one though. I also would not bend it at a smaller radius than this. heres some pics.
Andrew
eznfrank
| posted on 8/4/08 at 09:22 PM |
That looks like a much better idea than all this p1ssing around with rose joints and rods at ridiculous angles. I've just seen some of those
cables on the bay for about £15 - bargain.
| posted on 8/4/08 at 09:36 PM |
We did have a rod gear change but have since fitted a cable operated paddle shift. We used a series 4 control cable from
Cable-Tec .
Here's a picture of the connection to the paddle shift.
  Paddle shift end
And here's the connection on the gear lever
  Gear lever end
If you need any other pictures or further details, let me know.
Phil
matt.c
| posted on 8/4/08 at 10:20 PM |
mine is pants too! so much play!
Making a new one now but very interested in the cable option.
Hellfire, How much did the cable cost?
ReMan
| posted on 8/4/08 at 10:24 PM |
This is mine...
Still pleased with it thoug I think it may be a little worn inside from a tight curve an may need replacing after 2 years use.
http://www.locostbuilders.co.uk/viewthread.php?tid=35650
worX
| posted on 8/4/08 at 11:18 PM |
I think a price of £40 is acheivable no matter where you order it from...
U2U
Stevequote: Originally posted by matt.c
eznfrank
| posted on 9/4/08 at 09:02 AM |
Thanks for all the responses, think I'll give this a go, why don't more people do that rather than all the rods and rose joints??
But now I'm thinking, what's to stop me using a push/pull solenoid and having a button shift, that would be pretty cool I reckon.
Or would it not work cos the solenoid would not return to center?
[Edited on 9/4/08 by eznfrank]
| posted on 9/4/08 at 11:25 AM |
The cable was about £35 IIRC. Probably best to give them a ring though.
Some people prefer the feel of the rod operated shift. We personally went for the cable because we felt it was a neater solution and more direct.
Phil
locoboy
| posted on 9/4/08 at 12:01 PM |
I have a shift cable available for £20 + pnp if your interested?
I will measure later and give the manufacturer etc
It cost me £35 and i didnt use it - only because i couldnt find the bloody thing!
Locoboy
eznfrank
| posted on 9/4/08 at 12:18 PM |
Yeah if you could u2u me the details re: length, and what size the ends are etc,and I'll let you know.
locoboy
| posted on 9/4/08 at 06:26 PM |
I couldnt figure out how to post a pic in U2U so here it is, excuse the quality it off my phone because my camera batteries are dead.
Its made by B&M - link to someone selling their cables. Click
Overall length is 920mm
Length of casing is 750mm
Throw 65mm
Threaded end is M5
Eye end is 6mm Diameter hole
Cable sheath is 10mm Diameter.
Securing hole at eye end is 6mm diameter
Bulkhead or panel securing end needs a 12mm diameter hole then it clamped with a nut either side of the bulkhead or panel.
Part number on the cable is B&M 4000990 2C2 OR
Hope that helps
Poxy photo wont show!
[Edited on 9/4/08 by locoboy]
Locoboy
Ali_Minium
| posted on 16/5/08 at 07:17 PM |
Paddle Gear Change
We at KEP Engineering currently make an aluminium billet paddle gear change that has been used in the race winning stm pheonix(the purple car in front
of you!) and now the aries motorsport 7. After talking with Steve at Aries today I am re-designing the shift system to be fully SVA compliant
(collapsable, fixed steering wheel) with the option of the removable steering wheel (not SVA) at no extra charge. The system replaces the old Ford
steering assembly and is easily retrofitted to most sequential gear boxes (generally bike engines) it will come with most fittings necessary to get
you going but may need brackets for certain fitments - we can advise. This is a new project for us and we would apreciate feedback before we invest
too much! The kit will sell for £349.99 and be available in various colours (Gold, Black, Red, Blue, Silver etc.) Please reply as this is my pet
project and I would like to get it right. Is the price right? We could probably reduce it but in my opinion it would compromise the product. I have
seen other versions and they would look good on farm machinery, but ours is the biz!! its going on My Phoenix! I will upload pics when I have
them - there should be some on the Stuart Taylor site, and other bits we made - see "shiny bits".
Sean
seant@sky.com
KEP Engineering Ltd
tel 01159 780777
fax 0115 9422000
[Edited on 16/5/08 by Ali_Minium]
richard thomas
| posted on 16/5/08 at 08:00 PM |
Just found the thread and have a general question. You might have to excuse my ignorance, but I struggle to understand how anyone can build a rod type
gearchange linkage that creates any more play than a cable linkage has? I am well aware of the inherent benefits of the cable, but at the end of the
day, it still has 2 connection points - one to the gearstick/paddle, and one to the gearbox lever. These will inevitably be subject to the same hole
tolerances as a rod type linkage. It's not as if the route of a gearchange linkage on a 'seven' type BEC is particularly
convoluted....i.e. forwards down the tunnel, turn right through 90 degrees. End. (for a tunnel mounted stick - for a paddle it's a not much
worse, forward through the bulkhead, turn down through 90 degrees. End)
I made mine from a couple of small kart rose joints from demon tweekes, and a length of steel tube from B&Q. Not overly expensive. Or heavy.
Absolutely no free play. At all. None. Other than the couple of millies that the gearbox selector lever moves before engaging next gear. Plus
it's a lot easier to lube a rosejoint than it is to strip and lube a cable...(anybody tried?)
Is it perhaps that the (poor?) design of some linkages are making the cable method attractive?
Ali_Minium
| posted on 16/5/08 at 08:25 PM |
Paddel Gear Change
The differences between a good cable set-up and a good rod set-up are minimal. The advantage of cable is that you are able to use the same adapter
points (the point where the cable connects to the linkage) on various applications, enabling positioning to be more flexible. Every engine is
different. This can also be achieved with rods but may need modification, ie lengthening / shortening of the rod length. There may also be extra play
if rods need to be extended/re-routed. Rods also add a certain amount of torque to the equation and depending on the angle can induce some flex in the
linkage whereas a cable puts the energy exactly where it is required.
Hope this helps
Sean
richard thomas
| posted on 16/5/08 at 08:49 PM |
Thanks Sean,
I guess I was lucky enough to build my linkage from scratch, so no flex issues involved. But surely if the position of the engine becomes an issue,
then it's only a case of redesigning the linkage properly? Providing the correct ratio's in the bellcrank keeps the change feeling tight.
I have to admit, mine was a case of trial and error as it was built.
