welderman
| posted on 10/4/08 at 11:09 AM |
R1 Sump Chop, now with picture's
Anyone done there own sump chop, thinking of doing my own, any issuse doing this, ie pick up pipe, baffle etc.
Any info welcome.
Or can you buy sumps already made smaller?
[Edited on 10/4/08 by welderman]
Thank's, Joe
I don't stalk people
nitram38
| posted on 10/4/08 at 11:25 AM |
Why do you want to chop it?
It isn't very deep as it is.
hobbsy
| posted on 10/4/08 at 11:35 AM |
Which R1 engine do you have?
The 4XV sump holds less oil than the 5PW so I'm guessing it shallower?
Only really helps if you've got a 4XV.
However as in the previous post (other than ground clearance) why would you want to do it? People often go the other way to increase the oil
capacity.
smart51
| posted on 10/4/08 at 11:36 AM |
You will reduce the oil capacity if you cut the sump. Its a bit lower than I would like as it is. You would probably have to dry sump it if you cut
it.
You would need to shorten the pickup pipe, or plumb it to your dry sump system. You'd need to shorten the drain tubes too.
TimC
| posted on 10/4/08 at 11:45 AM |
Agreed, the R1 sump is shallow!
welderman
| posted on 10/4/08 at 12:35 PM |
it's an option im thinking of doing, as ive no wheels for my Fury yet, it looks low now and im sure the engine sits too low, approx 60mm from
bottom chassie rail at the moment. I re-made the mounts to allow the sump to sit flat as it was intended in a bike too.
R1 2003 fi engine.
Will nip downstairs and take a picture.
Thank's, Joe
welderman
| posted on 10/4/08 at 12:38 PM |
1
Thank's, Joe
welderman
| posted on 10/4/08 at 12:39 PM |
2
Thank's, Joe
welderman
3
Thank's, Joe
nitram38
| posted on 10/4/08 at 01:41 PM |
Even a dry sump will stick out on that!
You need to raise your engine.
bassett
| posted on 10/4/08 at 02:03 PM |
Having taken my 5PW sump off at the weekend i personally wouldnt as would be a heap of unecessary work when its surely easier to raise the engine
mounts, although you might need a bonnet vent.
Adam
andy o
| posted on 10/4/08 at 02:31 PM |
i was told that the join between sump and block should be level,not the bottom of the sump!hope i've been told right for my sake and wrong for
yours!anybody know which is right?mines a 5vy by the way
andy
welderman
that will do me, rase engine it is
Thank's, Joe
Minicooper
| posted on 10/4/08 at 03:53 PM |
andy
The bottom of the sump should be level as Welderman has it, but I have seen a few cars that run with the joint level and as far as I'm aware no
problems
nitram38
| posted on 10/4/08 at 04:01 PM |
I have a few R1 sump baffles for sale which fit 04-07 engines. u2u me.
ChrisGamlin
| posted on 10/4/08 at 09:20 PM |
The R1 sump is very difficult to chop anyway, not because of the sump itself but because of the pickup design which is very difficult to shorten
without serious amounts of work, coming down from the block at an angle rather than vertically like most pickup pipes do.
adithorp
| posted on 10/4/08 at 09:57 PM |
The Kit Car Workshop used to recommend having the seam between the sump and engine level with the bottom of the chassis. Mine is slightly higher than
this (not much). Without measuring I'd say 40mm (I'll check tommorow) giving me about 100mm ground clearence. There's a couple of
down sides to this.
First is that the engine is leaning over backwards a little compared to the bike fitment. Opinion seems to be split on this but personally don't
see it as a problem. After all the bike doesn't sieze up going up hill or pulling wheelies. From what I hear the bikes spend most of thier lives
with the front wheel in the air!
Secondly the drain plug isn't at the bottom; I plan to get hold of a second sump and have the drain moved at some point....
I tried getting it in with the sump base level but it wouldn't work. It was too high (at the throttle bodies) and the exhaust didn't clear
the chassis rail.
adrian
welderman
| posted on 11/4/08 at 12:18 AM |
thanks for the comments, and Adrian get your tyape out tomorrow,
Thank's, Joe
welderman
| posted on 11/4/08 at 12:21 AM |
it sits 25mm below the chassie rail now, but sat on ally blocks
Thank's, Joe
welderman
| posted on 11/4/08 at 12:22 AM |
blocks and bed time too
[Edited on 11/4/08 by welderman]
Thank's, Joe
PAUL FISHER
| posted on 11/4/08 at 12:41 AM |
Have you been out with the brasso Joe,polishing all them pipes,nuts and bolts,looks more like a steam engine than a bike engine
welderman
| posted on 11/4/08 at 06:45 AM |
Paul the engine is a brand new, 2003 R1. .
It's looking dirty now ive had it a few months.
Thank's, Joe
