stupott901
| posted on 24/4/08 at 07:43 PM |
blade loom
hi there
im after your invaluable experience again
im about to fit my blade engine to my mk indy
and i was wondering as i have got the nearly the the full blade loom ,and an loom from mk do i ?
1. use the blade loom and use the mk loom to extend to front and rear lights and fuel pump etc?
2. or do i just use the engine part of the blade loom and use the mk loom for dash and lights etc
thanks stu
worX
| posted on 24/4/08 at 08:54 PM |
Unless you are putting in extra spotlights or a heated front screen etc. there is absolutely no need for you to use the MK loom. You can make
everything you need, work, with the Blade loom...
HTH
LBMEFM
| posted on 24/4/08 at 09:30 PM |
I used my Blade loom for front lights/engine etc and extended it to the rear lights with multi-core trailer cable.
stupott901
| posted on 25/4/08 at 08:37 AM |
thanks guys for advice
wish i had asked earlier as i have only just finished labelling up the mk loom over the last few evenings
cheers
stu
