iiyama
| posted on 24/4/08 at 07:45 PM |
Busa speedo sensor
The sensor seems to be a magnet and what it appeared to sense a metal disc with four splines on it. So...
What have others done? Looking for mounting inspiration and tech details!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
richard thomas
| posted on 24/4/08 at 08:20 PM |
Skip the disc, make a bracket to mount the sensor close (i.e. very close) to the 4 bolt heads that will connect your prpshaft to the prop adaptor
flange. Worked for me anyway...
iiyama
| posted on 24/4/08 at 08:24 PM |
So I guess it dosent matter that the four bolts are not set equally?
| posted on 25/4/08 at 07:31 AM |
no but the number of bolts matters - in your case this matches the slots in the disc.
richard thomas
| posted on 25/4/08 at 08:44 AM |
Didn't make any difference to mine...
iiyama
| posted on 25/4/08 at 10:34 AM |
K guys, thanks for that.
One last question. That area of the car, (ie the prop flange adapter), is pretty crowded so I am thinking of moving the speed sensor down the tunnel
and mount it somewhere around the center bearing. If I do this then obviously those aforementioned bolts aint gonna be around so what can I substitute
them with? Am thinking of gluing four small neodymium magnets to the prop. Would this work or should I use something non magnetic?
timbo7
| posted on 1/5/08 at 09:56 PM |
see my U2U
WESTFIELD HAYABUSA 1400 - SOLD
lococost
| posted on 2/5/08 at 04:20 PM |
They don't need to be magnetic, they just need to be able to attract magnets, so iron will do. I had the same space issue at the front so I
placed mine on the driveshafts (added advantage that you'll have less revolutions so less probability to imbalance). Just welded some pieces of
iron to the boltholders. It's a GSXR1000, same system as GSXR13000. Work fine
more info on the www below.
marc n
| posted on 2/5/08 at 06:08 PM |
two magnets on prop near sprocket adapter ( easy to get to ) gets to within 1mph acciuracy with speedo healer up to 100mph
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
