Author: Subject: R1 sidelights
andy o
posted on 29/4/08 at 07:45 PM Reply With Quote
R1 sidelights
i'm using r1 switchgear and clocks(5vy) on the fury and as far as i can tell from the r1 owners manual the headlights come on with the ignition,so what is the best way to wire the sidelights in.do i just fit a 3 position switch ie.off,sides,headlight.i should add that wiring a plug is my limit with electrics so keep answers simple please!!!
thanks andy
eccsmk
posted on 29/4/08 at 07:54 PM Reply With Quote
i think you will have to wire the side seperately as it needs to work when the ignition is off
i used a seperate fused feed from the battery
HTH
worX
posted on 29/4/08 at 08:29 PM Reply With Quote
I don't have an R1 manual to hand, but I think you may be able to put a switch in the Brown with Red wire. that way there is a break in it until you've "switched" it back on.
HTH
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 29/4/08 at 08:50 PM Reply With Quote
I'm using a 5pw loom and clocks but have swapped the right hand switchgear for the earlier type (5jj or 4xv i believe) as they have the on/off switch and rewired it to suit.
Like this one
http://cgi.ebay.co.uk/YAMAHA-R1-1999-4XV-RIGHT-HAND-SWITCH-YZF-R1_W0QQitemZ350046115518QQihZ022QQcategoryZ10490QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ _trksidZp1638Q2em118Q2el1247
[Edited on 29/4/08 by CRAIGR]
adithorp
posted on 30/4/08 at 11:55 AM Reply With Quote
Side lights don't have to work with ignition off for SVA (altough thats the normal way).
adrian
Coose
posted on 1/5/08 at 07:57 AM Reply With Quote
adrian
But they do for subsequent MOT's.
There should be a side light circuit as part of the ignition switch circuit.
Spin 'er off Well...
