Author: Subject: Can I mount my radiator upside down??
eznfrank
posted on 1/5/08 at 10:38 AM Reply With Quote
I'm building an Indy with a ZX12 block and using a Polo radiator. Ideally I would like the rad inlets to be on the opposite side and wondered if I can simply turn the rad upside down to achieve this??
The thermostat is half way down the rad so it will be in the same position upside down and I will conveniently have a drain point at the bottom which can be plugged during normal use?
Anyone see an issue with this??
Mr Whippy
posted on 1/5/08 at 10:41 AM Reply With Quote
yes, makes no difference.
unless there is a filler which might be a bit amusing check if there is an overflow pipe, that should always at the top to let vapour out.
speedyxjs
posted on 1/5/08 at 10:46 AM Reply With Quote
Yep its fine. A few others on here have done the same
RazMan
posted on 1/5/08 at 11:45 AM Reply With Quote
Polo rad is sealed apart from the fan switch - and that doesn't mind being upside down either
Raz
John.Taylor
posted on 1/5/08 at 11:50 AM Reply With Quote
My Polo rad has an outlet to the expansion tank at the top in addition to the flow and return. Wouldn't this cause problems being upside down?
eznfrank
posted on 1/5/08 at 12:06 PM Reply With Quote
I'm using a Golf header tank as an expansion tank (as tired and tested by others) and intend to block off the expansion outlet as the header is mounted on a T.
The outlet on the rad will be at the bottom so I will blank that off and use it to drain the system shoul di ever have to?
John.Taylor
posted on 1/5/08 at 12:18 PM Reply With Quote
I spent some time looking at expansion tanks in scrapyards and found that the Ford KA has a very compact pressure cap version with an expansion inlet which is the same size as the polo radiator outlet.
It's so small I managed to mount it on the front chassis top rail under within the nose cone.
