Sebastian
| posted on 5/5/08 at 07:44 PM |
ZX-9 Speedo connector, where is it??
Hi Guys,
I have a 2002/2003 ZX-9R engine (Carbs) but i can't find the connector for the speedosensor, i am using the standard loom and clocks.
Or is this an electronic speedo?
Who has a picture of the connector, i am probably looking over it but i am totaly in the dark at the moment.
Thanks.
| posted on 5/5/08 at 07:49 PM |
I think it's the one with the yellow and pink wires to it on the older engines, it reads from the sprocket nut. It might be same on yours.
the speed sensor an my 1998 engine is built into the sprocket cover, hence not present on a 7 style car.
Sebastian
| posted on 5/5/08 at 08:03 PM |
@JoelP, i have that end of the sensor with the connector however i can't find the other end on the wiringloom on the engine.
@Peteff, will search for a pink wire if it's there it should be to difficult to find.
