Author: Subject: wanted urgently.R1 FUEL PUMP&TILT SENSOR
andy o
posted on 11/5/08 at 11:17 AM Reply With Quote
HI,need r1 injection pump and tilt sensor.
gotbthe week off but my plans are all based around getting engine running,any help with this would be great
thanks andy
ko_racer
posted on 11/5/08 at 11:41 AM Reply With Quote
I've not got a fuel pump but I have a tilt sensor you can have. From 5vy/5pw
The other option is to bypass the tilt sensor completely by sticking a 470 ohm resistor between the blue and yellow/green wire and removing the tilt sensor. This is a much safer way of doing it unless you want the funtion of the cut off switch for some reason.
I've even got a resistor you can have if you want.
The same resistor is used to bypass the level sensor on the fuel pump (green/white to black)
Drop me a mail at keith@koracing.co.uk if you like. I've fitted ost of the injected R1's at some point and am happy to give you my mobile no if you need some help during the week.
andy o
posted on 11/5/08 at 11:46 AM Reply With Quote
hi,thanks for that,can you u2u me a phone number?
thanks andy
