adam1985
| posted on 20/5/08 at 07:48 PM |
anyone got mounted r1 engine pics
as title really any build pics of a r1 engine in place just to help me position mine
r1 locost
| posted on 20/5/08 at 07:59 PM |
u2u sent
tjoh84
| posted on 20/5/08 at 08:23 PM |
in my archive
r1 locost
| posted on 20/5/08 at 08:45 PM |
mail is on it's way to you now!!!
ChrisGamlin
| posted on 20/5/08 at 09:20 PM |
Some 5PW ones in my picture archive too
lsdweb
| posted on 21/5/08 at 06:23 AM |
Some 5JJ and 5VY ones in my archive and on my web site
Wyn
[Edited on 21/5/08 by lsdweb]
locoboy
| posted on 21/5/08 at 06:25 AM |
4xv in my archive too.
I had to make it up as i wnt along as my chassis was not a bike engine specific chassis so mine may be worth a look.
I put a bit of timber across the bottom chassis rails and dropped the engine in so i could slide it about until i got it in the right place then made
up my mounting points etc.
It was all largely dependant where the exhaust would allow the enigne to be placed with just fine fettling to get a decent look and fitment.
hope that helps
Here you can see the wood and G clamps holding it in its temporary position
  bonnet nose side trial fit
[Edited on 21/5/08 by locoboy]
Locoboy
adam1985
| posted on 21/5/08 at 01:07 PM |
"I put a bit of timber across the bottom chassis rails and dropped the engine in so i could slide it about until i got it in the right place
then made up my mounting points etc. "
i thought the sump needed to be just below the chassis or its to high up in the bonnet
ChrisGamlin
| posted on 21/5/08 at 05:38 PM |
I did the same with a sheet of plywood clamped to the chassis to act as a table to sit the engine on when mounting, I needed it lower than level
though so just put some 1" pieces of wood on the bit that clamped up against the chassis rails, which gave me the required ~1" drop.
[Edited on 21/5/08 by ChrisGamlin]
adam1985
| posted on 21/5/08 at 07:49 PM |
how much lower should i go obviously not to far cause of speed bumps and stuff but dont want it stick out the bonnet or handle funny cause its to high
locoboy
| posted on 21/5/08 at 11:28 PM |
If you see in the picture the bit of wood the engine sits on is not level with the lower rails, it sits about 40mm lower because i packed it ouw with
bits of timber so the engine just fitted under the bodywork and was not 'too' low in the chassis to attract speed bumps!
Locoboy
