Author: Subject: R1 rectifier connection
progers
posted on 27/5/08 at 07:53 AM Reply With Quote
Hi All,
I have a spare '03 R1 engine and have just been preparing it ready for use if the other one goes bang (2 years racing and still going strong..).
I noticed that the connector to the rectifier (the one with three white wires) has been chopped off so I have a couple of questions
1) Anyone got a spare connector (or know where to source one)?
2) Does it matter the order in which the wires are plumbed into the connector?
Paul
TimC
posted on 27/5/08 at 07:57 AM Reply With Quote
Paul
Can you post a pic of the plug end of the rectifier? If it's the same as a 5JJ I think I have one.
TC
progers
posted on 27/5/08 at 08:06 AM Reply With Quote
Wow, that was quick!
I'm pretty sure its the same as the 5JJ, but I'll check the manuals to be sure. It would be great if you have a spare. Does it have wires already connected? Would be easier to connect the wires than play around with the connector itself. Let me know what you want for it
Paul
TimC
posted on 27/5/08 at 08:11 AM Reply With Quote
A paddock pass to a RGB race would be fine.
Will check tonight.
[Edited on 27/5/08 by TimC]
r1_pete
posted on 27/5/08 at 09:28 AM Reply With Quote
It doesn't matter what order the three white wires are connected in. Think of the alternator stator windings as three coils connected in a triangular configuration, with the white wires connected at each point of the triangle.
Its worth checking the winding too, use an ohm mete the resistance between any two whites should be about 5 ohms, and no continuity to ground. I did have one fail on mt R1
progers
posted on 27/5/08 at 10:10 AM Reply With Quote
Thanks - thought that was the case but thought I would check. I'll check the windings but I think they should be OK as the engine has not done many miles.
- Paul
