afj
| posted on 29/5/08 at 07:55 PM |
whats this
im trying to work out where this goes 2003 r1 5pw 60cm long one end is a 90 deg white plastic joiner and at that same end is some extra
protective pipe
t.j.
| posted on 29/5/08 at 08:13 PM |
looks like a hose for the battery or carb?
smart51
| posted on 29/5/08 at 08:16 PM |
looks line an engine or carb hose. Perhaps between a breather hole and the airbox.
The 4xv R1 engine has 2 hoses that go to a metal plate that bolts onto the cam tensioner. They're just open to the atmosphere from there.
afj
| posted on 30/5/08 at 01:07 PM |
i still cant see where it would go it def goes between something as both ends have spring clips on
Jubal
| posted on 30/5/08 at 03:03 PM |
I'm now initimate with the plumbing on my engine (5pw) and it doesn't appear to be any of the water hoses. Although, it might be
thermostat to expansion tank...
[Edited on 30/5/08 by Jubal]
