Author: Subject: fan switch
eddbaz
posted on 2/6/08 at 05:29 PM Reply With Quote
fan switch
Is it worth fitting a fan switch even though the fan is controlled by a temperature sensor, looking round a few bec car dashes I see a few people have them.
phoenix70
posted on 2/6/08 at 05:34 PM Reply With Quote
It really just a bit of a safety net. If you are stuck in traffic, you can switch it on before the engine temp needs it, giving you a bit of extra piece of mind. It isn't difficult to fit, so I would.
Scott
tjoh84
posted on 2/6/08 at 06:01 PM Reply With Quote
how do you wire one up to r1 engine switch in place but was not connected for some reason adfter being told to buy the switch
I never fitted one and so far have never needed one....
Just unecessary weight
adithorp
posted on 2/6/08 at 08:07 PM Reply With Quote
I didn't fit one and the rad copes but the R1 ecu switches the fan on and off at pretty high temp (100+). At fro SVAI had trouble controling emmisions untill Iran the fan constant.
Untill I have the dash out (when I'll fit a switch) I've run a wire from the fan positive feed to a cig lighter plug. I just plug this in to the auxilary sockets to run the fan.
Wish I'd put a switch in to start with.
adrian
