eccsmk
| posted on 3/6/08 at 12:08 PM |
slipper clutch
anyone using one?
are they needed in i bec ?
random i know but ive just been reading about them
also anyone used one of these??
moto46 link
[Edited on 3/6/08 by eccsmk]
PAUL FISHER
| posted on 3/6/08 at 12:29 PM |
Ive got one on my zx10r,its a handy addition,does make for a smoother rapid down change say from 6th down to 2nd or 1st into a hair pin,and has got to
put less stress through your gearbox,but not realy essential on a bec,more a requirement for a bike,stop the rear wheel hop under hard down
changes,and more importantly stop rear wheel lock if your engine seizes up,so spend your money elsewhere in my opinion.
dan__wright
| posted on 3/6/08 at 12:32 PM |
i was looking at using the cut on the powercommander, this sensor looks better than the power commander ones.
FREE THE ROADSTER ONE…!!
PAUL FISHER
| posted on 3/6/08 at 12:38 PM |
moto46 link
Ive not got one of those but I have got a trickshifter,great bit of kit,now these are worth spending your money on,certainly makes the car quicker to
drive,you make a couple of metres on a similar powered car every up change .
http://www.trickshifter.com/
r1_pete
| posted on 3/6/08 at 01:19 PM |
I've got one in the R1 <-, much more confidence slick shifting down a few gears to chuck it into a bend, but, on the bike if the rear locks
up in a bend 9/10 results in an unwanted get off. Can prevent over revving on downshifts and the resultant stresses, so, depending on how hard you
plan on driving you choose where to spend yot £ 000's
eccsmk
| posted on 3/6/08 at 01:44 PM |
moto46 link
cool ill ring the chap later
i used this company (moto46) for all my bike bits i.e. engine loom power commander
also will this help me change gear without the clutch ive ben practicing but its strange to get used to
PAUL FISHER
| posted on 3/6/08 at 01:59 PM |
moto46 link
Yes it will,up shifts on a bec can be done anyway without,but it allows full throttle upshifts which is the important bit,just keep your foot planted
to the floor while you change gear ,it will also blip the throttle on down shifts to allow you clutchless down shifts aswell
eccsmk
| posted on 3/6/08 at 02:05 PM |
thank you mr fisher
will your car be at mk on saturday??
wouldn't mind being nosey if possible
thank you
paulmw
| posted on 3/6/08 at 02:43 PM |
Forgive my ignorance as i havent riden bikes before. So whats the best way to change gear with a slipper clutch. I always use the clutch for all
changes, numerically up and down. Any tips considering I am on day 4 of driving it
Jubal
| posted on 3/6/08 at 02:45 PM |
See here Paul:
http://www.locostbuilders.co.uk/viewthread.php?tid=90407
I think it holds true for a slipper too.
Dangle_kt
| posted on 3/6/08 at 03:34 PM |
a slipper clutch should still be used with the clutch, it just gradually brings rear wheel speed in line with engine speed if you drop down the box
too quick, therefore stopping the rear wheels locking up/ putting tons of strain on the gearbox.
You can change UP without using the clutch, just weight the gear lever slightly, take the pressure off the throttle and snick it into the next gear,
then back on the gas. it should be real smooth
PAUL FISHER
| posted on 3/6/08 at 04:15 PM |
thank you mr fisher
thank you
Yes might have a run down on saturday morning,if I do,I will take you out in it show you how it works if you want.
eccsmk
| posted on 3/6/08 at 05:08 PM |
thank you mr fisher
thank you
wonderful ill bring my spare pants
