iceman26
posted on 7/6/08 at 04:11 PM |
help please
i have just about had it with this car now
i have afazer engine same as r1
can someone please help i cant get a spark engine turns over but no spark
can some one give me some pointers as i wanted to get the sva booked
but i ned to have it running before i will book it
thanks
[Edited on 7/6/08 by iceman26]
| posted on 7/6/08 at 04:12 PM |
Motorbike engines have lots of interlocks to stop you from starting the engine unless you're in neutral, clutch down, sidestand down etc. You
need to make sure they're all correct (or earthed, sometimes via resistors etc) before you'll get any sparks....
iceman26
| posted on 7/6/08 at 04:15 PM |
clutch switch bridged sidestand also bridged kill switch bridged and have been told neutal will not stop it starting
adithorp
| posted on 7/6/08 at 04:20 PM |
If ti was any of the interlocks it wouldn't turn over. Which way up is your tilt switch? It sould have the word "UP" on the top, not
on the side with the word the right way up.
adrian
iceman26
| posted on 7/6/08 at 04:38 PM |
makes no diffrace have tested at all angles
worX
| posted on 7/6/08 at 04:40 PM |
Does your fuel pump prime when you turn the ignition on?
iceman26
| posted on 7/6/08 at 04:52 PM |
no it is not
The Great Fandango
| posted on 7/6/08 at 05:54 PM |
I'm afraid I'm no help to you on this electrical subject as the engine was wired in before I bought my car...
... but wanted to say how nice it is to hear of another Fazer engined owner.
They say the Fazer is the same as the R1 but I've learnt there are many differences. For example when my clutch went I found the mechanism is
completely different. NB: It uses plates with the same dimensions as the Yamaha R6, the R1's are much bigger.
You are welcome to visit (Leeds) to have a look at my wiring for inspiration. As a non road going 'racer', the wiring's fairly easy
to get to.
If you U2U me your e-mail addres I can send you scanned pages from the Haynes Manual which might help?
He Who Dies With The Most Toys Dies The Happiest
Lee MacPherson
| posted on 7/6/08 at 06:31 PM |
Are you using the original bike harness, it may have a 6-way and a 3-way connector for the cyclelock immobiliser, they both need a link fitted if you
have the cyclelock.
iceman26
| posted on 7/6/08 at 09:44 PM |
a big thank you to chris mason
worX
| posted on 8/6/08 at 05:34 AM |
You say that now, but wait for his invoice via U2U!
(only kiddin'     )
mad-butcher
| posted on 8/6/08 at 07:58 AM |
take it it runs now
