RickRick
| posted on 10/6/08 at 07:29 AM |
R1 5VY Water system
Just started looking at getting all the water pipes and rad fitted to my R1 5vy there seems to be a lot of small bore pipes that i'm not too
sure about could someone give me a few hints
Thanks Rick
worX
| posted on 10/6/08 at 07:41 AM |
I don't know whether this is applicable to yours but here goes:
  Cooing with "Wyn-tech"
adithorp
| posted on 10/6/08 at 11:12 AM |
1.Bottom hose to rad bottom hose.
2.Top hose to rad top hose.
3.Expantion bottom outlet Tee'd into either bottom hose (preferable) or top hose (thats where mine goes 'cos it was easier).
4.Thermostat bleed pipe and rad bleed pipe into expantion bleed pipe (use the Tee from 6).
5.Oil cooler outlet Tee'd into top hose.
6.Small pipe from bottom near sprocket and main bottom hose to throttle body thermo' valve (loose the Tee).
7.Other side of thermo' valve to pipe behind stat on head outlet.
adrian
[Edited on 10/6/08 by adithorp]
Davey D
| posted on 10/6/08 at 03:30 PM |
On mine ive done:
Bottom pipe on radiator to bottom pipe on engine
Top pipe on radiator to top pipe on engine ( thermostat)
small pipe form thermostat into the top pipe
Oil cooler outlet to bottom pipe
small top outlet on polo radiator to bottom pipe on expansion tank
pipes from near the sprocket + throttle body to the top pipe on expansion tank
