Lightning
posted on 5/12/03 at 11:05 PM |
Fireblade switches (also in wanted)
I am trying to use the fireblade switches.
I have after much buggering about found that the light Hi Lo switch is u/s.
Has anyone out there got one please.
PS: I was initially confused as the book shows 2 relays, one for Hi and one for lo. My loom only has Hi relay and appears to use the switch direct for
Lo.
This could of course be contributary to failure.
Thanks in anticipation
posted on 5/12/03 at 11:58 PM |
Relays
This is maybe, possibly, probably why the switch is u/s in the first place - the current is too high for the switch.
IMHO for this kind of current you you're safer using relays for both Hi and Lo circuits.
Lightning
posted on 11/12/03 at 02:29 PM |
Have got it sorted now.
I put an on/off rocker switch on the top of the switch cluster and wired it in to a relay that switches from the lo to high.
By the way putting the hazards in is a doddle once I used a dipolar switch.
posted on 13/12/03 at 05:44 PM |
Bipolar switch
isn't that a conflict in terms.... I'm bipolar aren't I? Oh yes. Well then... ermm who am I?
What are you talking about
Could you explain a little less deep and a bit more simple? Please, ta very much, cheers thanks!
