Author: Subject: clutch cable chafing
afj
posted on 18/6/08 at 07:32 PM Reply With Quote
ive just fitted the clutch cable on my indy R1 using some parts from an AA man i know. trouble is the cable is going to chafe on the tube through the bulkhead ...what have you guys used to prevent this thanks alan
richardh
posted on 18/6/08 at 07:44 PM Reply With Quote
mine has nuts both side of the cable threaded rod ends.
would it not chafe if you moved the position slightly.
got a pic?
afj
posted on 18/6/08 at 09:14 PM Reply With Quote
sorry no pictures as cam is away. i think i may have it sorted, used a left over plastic/nylon bush from handbrake bits and modded to line hole and PU 'd in time will tell
