Author: Subject: how to remove AIS from R1 quicky
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 4/7/08 at 12:29 PM Reply With Quote
I know I should block the ports left into the exhaust chambers, and the pipe from the crankcase breather can be replaced by a breather, but can anyone tell me the best thing to do with the small pipe that runs from just under one of the carbs to the AIS,
ie should I block it or leave it open?
richardh
posted on 4/7/08 at 12:52 PM Reply With Quote
i left mine open
haven't noticed any issues so far............
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 4/7/08 at 01:01 PM Reply With Quote
Good to know as mine currently open but...
As far as I can make out, it seems to carry a vacuum to a switch like a vac advance in the AIS, which I guess is a sealed unit, and so I would be inclined to seal it?
Anyone know definitely??
cheers
StevieB
posted on 4/7/08 at 04:51 PM Reply With Quote
Malc at Yorkshire Engines told me to take off the AIS and just link one outlet back into another with some hose, so you have two loops.
If I have time, I'll be making something using copper pipe (or maybe ali, if I can get it TIG'd somewhere)
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 4/7/08 at 05:05 PM Reply With Quote
Guess that would work, but the fittings can slip off quite easily and with the weight of the pipes unsupported...
I just cut my tubes, squashed them in a vice, bent them over and squashed them again!
Still need to know best thing to do with the carb narrow pipe though!
Ed
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 4/7/08 at 08:21 PM Reply With Quote
Anyone??
Coose
posted on 5/7/08 at 09:57 AM Reply With Quote
Leave it in place. It doesn't cause any problems.
Spin 'er off Well...
StevieB
posted on 5/7/08 at 02:47 PM Reply With Quote
I was under the impression it causes problems with the SVA emissions test for a car application.
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 5/7/08 at 07:17 PM Reply With Quote
It can also make it impossible to be properly tuned on a rolling road as the action of mixing air in confuses the readings etc.
Anyway, it's already off!
Coose
posted on 6/7/08 at 10:55 AM Reply With Quote
It doesn't if you don't connect up the rubber hoses. The valves stay closed as if they're not there as they only open on a vacuum in the inlet tract.
Mine did 7000 flat-out miles and ran perfectly!
StevieB
posted on 6/7/08 at 10:56 AM Reply With Quote
t shouldn't cause much of an issue on a rolling road because IIRC it's only active when the engine's cold. I think. Maybe.
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 6/7/08 at 11:12 AM Reply With Quote
That makes sense. But my power to weight ratio has shot up since I took it off, by at least, oh I dunno, but I also plan to have a pee before next track day and wear no socks...whohoooo!
That tract is the one I'm trying to find out about I would guess. I presume it should be closed off then?
StevieB
posted on 6/7/08 at 11:59 AM Reply With Quote
Eat plenty of fibre for a week before too -hed a bit extra weight
A u2u to either Malc (Yorkshire Engines) or a call to MNR will probably give you the answer
