Author: Subject: bec spark plugs
mkblade
posted on 13/7/08 at 11:34 PM Reply With Quote
bec spark plugs
hi all
im getting my carbs back this week from ab performance hopefully he scured the problem
question is has anyone managed to re use a set of plugs that have been well flooded in petrol they look ok and only done two miles before it broke down.
didnt really want to spend another £35.00 on plugs
thanks simon
nitram38
posted on 14/7/08 at 06:51 AM Reply With Quote
Put them in the oven on a low heat for a while, it will help and give them a clean with a small brush.
Try that before you bin them!
posted on 14/7/08 at 07:21 AM Reply With Quote
I suppose it's worth trying to "restore" them but in my experience like most things BEC the sparks are a little fragile and go all grumpy if you flood them.... Certainly when I did this whilst setting up my car I knackered a set of brand new plugs and had to swap them for the ones that originally came with the engine.... no amount of heat or time appeared enough to remove the fuel....
russbost
posted on 14/7/08 at 12:17 PM Reply With Quote
Unless the plugs are damaged in some other way I've always been able to recover them by cooking as Martin describes, just as a pointer I went 2 grades hotter on my plugs to stop fouling & despite hard use have never had any eroding/melting electrode problems.
Coose
posted on 14/7/08 at 01:46 PM Reply With Quote
You're brave! You shouldn't need to run hotter plugs than stock, but you really need to watch out for holed pistons....
Spin 'er off Well...
Andy B
posted on 14/7/08 at 04:26 PM Reply With Quote
bec plugs
Hi Simon
Just spotted your thread, a point on wirebrushing them - works fine on the standard NGK's but if you are using the iridiums dont put a wire brush anywhere near them - you will be virtually guaranteed a permanent misfire afterwards!
Let me know how you get on
regards
