Author: Subject: '94 Blade, Rectifier wiring
Gav
posted on 14/7/08 at 10:14 AM Reply With Quote
Now ive got my engine running, i have found that the rectifier input wiring (the 3 yellow wires) are getting so hot they are starting to melt.
I thought that it didnt matter which way round these wires were connected, any ideas?
cheers.
Dangle_kt
posted on 14/7/08 at 10:18 AM Reply With Quote
regrec might be fubbard - honda had a knack of making crap regrec's in the 90's - leads to your battery giving up the ghost in the end.
Do you have a mate you can borrow one off locally to test?
Could also be wiring, but thought I'd give you the benefit of my experience
simoto
posted on 14/7/08 at 10:36 AM Reply With Quote
On my similiar part there is a larger green wire too. By its position it can only go to the pos/neg term or earth.
Anyone shed light please, sorry to hijack.
si
striker/blade now complete, thanks to all on this site.
r1_pete
posted on 14/7/08 at 11:04 AM Reply With Quote
cheers.
It doesn't matter which way the yellow wires are connected, think of the alternator stator as a triangle with each side being a coil and each point being the wiring connector.
As already said Honda regs are pretty poor on some models, there is an excellent podtronics aftermarket unit available try here
[Edited on 14/7/08 by r1_pete]
Gav
posted on 14/7/08 at 11:17 AM Reply With Quote
Sorry, i neglected to mention, i am already using the one from the Superdream as recommended on this site.
I have the original one from the bikes loom so ill try that one instead.
rf900rush
posted on 14/7/08 at 03:07 PM Reply With Quote
Hi
Had problems with my CBR400RR NC29 Baby blade.
Fitted a spare Suzuki GSXR600 Reg. I had . Worked for a while then that blew.
I then found the stator coils were U.S.
Thats was proberbly the cause in the first place.
When I checked the coil output first time using a 12v bulb across each pair it seem ok.
With a new coil it blew the bulb instantly.
Just a note I got my need stator from
Here
Very happy with their Service.
Note:
the wiring seem the same one many bikes.
3 wires to the coils (3 phases ) one to Chassis and one to battery 12v.
hector
posted on 14/7/08 at 05:09 PM Reply With Quote
As said before they were a problem on the blades, I just replaced mine on my 92 RRN (brand new one from www.wemoto)
If you have beeen using it for a long time in that state your battery may well be shagged aswell, cos if the batt is not tip top it can cause the new rect/reg to burn out.
I replaced batt aswelll and my wires do not get hot at all now, hope that helps
cheers colin
