Author: Subject: Busa speedo healer not working
finlay
posted on 23/7/08 at 07:00 PM Reply With Quote
hi again all
well i now have the problem of my speedo not working
the set up im using is
original busa speed sensor on a bracket over the gearbox output shaft flange which i have fitted 2 tabs @ 12 oclock and 6 oclock for the speed sensor to pick up
im also using speedo healer and original busa inst/clocks
unfortunatly it aint working, i followed all the instructions to a tee but still nothing, no indication of any speed at all, i followed the test set up instructions of the speedo healer, it all works up until it asks you to spin the rear wheels to make the t for test mode flash, well it doesnt flash, but i can move the needle on the original busa clocks move about, so the speedo healer must be doing something
anyone else had this kind of problem or any solutions ?
much appriciated
cheers
Finlay
marc n
posted on 23/7/08 at 07:07 PM Reply With Quote
hi finlay you need two magnets at 180 dgrees and sensor flat side pointing to them
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
marc n
posted on 23/7/08 at 07:13 PM Reply With Quote
ps.
this has worked on six busas so far that had no speedo working trying to use tabs as a trigger, i used etbs magnet that come with the digidash if you email me i can send you a couple in the post
cheers
marc
finlay
posted on 23/7/08 at 09:05 PM Reply With Quote
excellent
cheers Mark
i will send chris an email with my address
richard thomas
posted on 24/7/08 at 09:50 PM Reply With Quote
I set my original sensor to pick up on the propshaft adaptor flange bolts - worked a treat with speedo healer.
Doesn't seem to make a difference that the bolts are not equi-distant around the circumferance....
OX
posted on 25/7/08 at 07:46 PM Reply With Quote
they dont need to be magnets , but make sure you dont use stainless
finlay
posted on 27/7/08 at 06:03 PM Reply With Quote
got the speedo healer working with magnets
cheers
