Author: Subject: Plumbing
Lightning
posted on 17/12/03 at 10:43 PM Reply With Quote
Plumbing
Where should I stick the air bleed pipe........tried that too uncomfertable.
No , I have the expansion tank off the overflow on the rad with the pressure cap removed and fitted with a blank. Pressure cap on the expansion tank. Am I doing this right?
By the way Blade engine....Micra rad
posted on 18/12/03 at 12:11 AM Reply With Quote
we're doing it different...
three way joint to header/expansion tank, then leave everything else as it is.
Same set-up as yours. Have you wired your fan switch and thermostat up yet? If so I'd like some help...
