afj
| posted on 26/7/08 at 05:44 PM |
r1 clocks sva
hay everyone, do you actualy have to be able to see the clocks when they are mounted on the dash, im trying to put them behind the wheel but
certain parts of the clocks not be visable ..... from a sva point
adithorp
| posted on 26/7/08 at 06:00 PM |
On the R1 dash you'll have to be able to see the speedo plus the indicator+main beam warnings from the drivers seat. You'll also have to
be able to see the brake and rear fog warning lights that aren't in the R1 dash.
adrian
afj
| posted on 26/7/08 at 07:19 PM |
thanks mate
stuart_g
| posted on 26/7/08 at 09:18 PM |
Why not recess them into the dash like this if you can't get them within the allowable radius of the steering wheel, no problem with SVA
then.
