Jon Ison
| posted on 27/7/08 at 06:20 PM |
Koenig Billet sump with swivel pick up ?
Anyone any experience of these ?
Good ?
Bad ?
If good best supplier ? ie best price ?
Ta.
Jon Ison
| posted on 27/7/08 at 06:39 PM |
this...........
worX
| posted on 27/7/08 at 06:41 PM |
Lyn (Fesycresy) has done some research into these and rates them quite highly (I think it's that model).
macspeedy
| posted on 27/7/08 at 07:35 PM |
yip i have one of them
watch what year its for i have had a few minor problems, look back at my previous posts for problems, i bought it from America from
these guys
[Edited on 27/7/08 by macspeedy]
macspeedy
| posted on 27/7/08 at 07:37 PM |
previous posts
TimC
| posted on 27/7/08 at 09:01 PM |
Good ?
Bad ?
Ta.
It's better be good if the 6 hour is on at Mallory again and Gerrards is dry!
imp paul
| posted on 28/7/08 at 06:27 AM |
don't know if they do busa sumps but they do zx12r swinging pickup sumps here http://www.novaracing.co.uk/products.htm
[Edited on 28/7/08 by imp paul]
iiyama
| posted on 28/7/08 at 06:36 AM |
These sumps are designed for drag bikes and as such the arm will swing a maximum of twice each run. On a car they will be moving all the time and
those in the know say that because of this the swinging mechanism can wear.
I can see arguments for and against this theory and so went with a sry sump in the end where the pro' far outwiegh the cons!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Jon Ison
| posted on 28/7/08 at 08:35 PM |
Should be ok emersed in oil ? How does it swing, are they on a bearing ?
eddbaz
| posted on 30/7/08 at 02:33 PM |
if you look at the picture of the keoing sump the pickup doesn't swing 360 deg as it is designed for a drag bike that moves in a straight line
and the oil surge is produced by hard acceleration in one direction only,when used in a car you have to consider the surge under cornering as well,if
you look at the swing pickup billet sump from ab performane you can see the pickup swings a full 360 deg which is what is needed if fitting this type
of sump to a car.
imp paul
| posted on 30/7/08 at 06:06 PM |
this is mine from nova raceing.jpg)
Koss
| posted on 14/8/08 at 03:09 AM |
I have the koenig hayabusa sump for my turbo zcars Monte Carlo. Looking at it the sump will hold almost twice as much oil as the standard busa sump
with the shark fin removed.
In my case the car will be drag raced and it seems the ideal set-up. The swivel pick up is totally submerged in oil and has a precision ground bearing
surface, so I doubt there will be any issues concerning wear. I cannot see any problems arising using this sump in a seven type application due to the
fact it caries more oil and it would take some serious G force to empty it.
Just my 2ps
