Author: Subject: Main jet query
locosaki
posted on 30/7/08 at 04:16 PM Reply With Quote
Main jet query
Hi all,
The answer to this question might well be obvious !!!
Here goes anyway...
If I'm running a bigger main jet (standard 132 and I fit a 160) Am I correct in saying I will have alter the float level so that it has more fuel in it
Cheers Mike
hector
posted on 30/7/08 at 04:56 PM Reply With Quote
NO
mistergrumpy
posted on 30/7/08 at 05:46 PM Reply With Quote
From my reckonings from Si's description on how carbs work. The carb will pull more fuel because of the bigger jet but the fuel pump should be more than adequate to re supply the float bowl so as above, no.
