Author: Subject: RX1N query
markyb
posted on 29/8/08 at 03:27 PM Reply With Quote
RX1N query
I have started to wire up my clocks and just wanted to check if I was doing it correctly. I just want to check if the backlight should always be on once the key is turned (as per the case with mine at the mo) or should it only come on when I turn the dipped beam on
thanks in advance
Triggerhappy
posted on 29/8/08 at 03:32 PM Reply With Quote
On modern bikes the backlight allways goes on when ignition is on. (motor don´t need to run.
At least on my most recent babys: GSXR1000-05, Yamaha R1-04, Kawasaki ZX10R-04 and GSXR1000-03.
Not ment to brag, just indicate that it´s true for most brands!
Kriss
posted on 29/8/08 at 04:11 PM Reply With Quote
KOSO dash?
if so, yes, unit will alwya sbe in with the key turned, even without the engine running or if stalled!
markyb
posted on 29/8/08 at 04:31 PM Reply With Quote
one more thing stroked off the list
cheers
tootall
posted on 29/8/08 at 09:06 PM Reply With Quote
my gsxr 1000 k4 dash lightes up with key but i changed it so when i put lights on
some people dream of sucsess, others just get on and do it !!
tootall
posted on 29/8/08 at 09:07 PM Reply With Quote
tootall
Omni
posted on 29/8/08 at 10:03 PM Reply With Quote
Is there an echo in here???? lol
O
