IDONTBELEIVEIT
| posted on 29/8/08 at 10:11 PM |
I Wonder What This Connects To????
1995 fireblade 893cc was wondering where this connects to as there was no pipe on it when i brought the engine
cheers wayno
Are We There Yet, Are We There Yet!!!!
| posted on 29/8/08 at 10:16 PM |
Did you get an airbox with it? It looks like a breather.
ReMan
| posted on 29/8/08 at 10:23 PM |
That is correct, it normally goes to the breather thingy which is attached to the airbox
ReMan
| posted on 29/8/08 at 10:27 PM |
This bit...
myke pocock
| posted on 30/8/08 at 07:48 AM |
My manual calls it a 'sub-air cleaner housing' and it is simply a small plastic box with a foam filter in place. If you dont have one I
would think it would be easy to use a small off the shelf crank case breather filter. Dont leave it open though as all manner of nasty stuff could be
pulled in.
IDONTBELEIVEIT
| posted on 30/8/08 at 07:52 AM |
thanks fellas,how about this one,any ideas
cheers wayno:
mark chandler
| posted on 30/8/08 at 08:24 AM |
Carb Overflow
stevec
| posted on 30/8/08 at 10:32 AM |
Is it the pipe that connects to an air horn to warn you that the dog teeth have just fell off 2nd gear
IDONTBELEIVEIT
| posted on 30/8/08 at 10:51 AM |
it's usually fourth
indykid
| posted on 30/8/08 at 11:41 AM |
float bowl breather
tom
gingerprince
| posted on 30/8/08 at 11:51 AM |
Its where fuel p1sses out when you get a stuck float
indykid
| posted on 30/8/08 at 07:11 PM |
that too
tom
