Jason Fletcher
| posted on 10/9/08 at 01:43 PM |
One for those getting perfect results with gear shifters. What are you using?
Hi there
What gear shifters are people getting complete success with? I've been looking at the proshift and it looks nice but it’s a tad pricey.
I'm looking to get one with flappy paddles and clutchless up and down changes.
thanks in advance.
Jason
sucksqueezebangblow
| posted on 10/9/08 at 02:07 PM |
I went with the Flatshifter as I heard good reports and it does both Upshift and blipped downshift but haven't finished my build so can't
comment from experience.
The flappy paddle arrangement was supplied direct by MNR.
http://www.flatshifter.com/
Jason Fletcher
| posted on 10/9/08 at 05:18 PM |
Thanks for that, I had a good chat to Flatshifter today and its looking promising.
have you got any pics of the paddles MNR supplied?
Jason
hobbsy
| posted on 10/9/08 at 05:35 PM |
FYI the Flatshifter looks as if it uses the exact same bits as the Trickshifter (for the shift rod sensor and blipper).
I'm interested in the MNR paddles.
Are they mechanical or electrical (used with a linear actuator shift rod thing)?
ginger ninja
| posted on 11/9/08 at 12:33 PM |
Just ordered a Flatshifter myself yesterday after chatting with Andy at AB Performance, if in doubt give him a call.
Meeerrrk
| posted on 11/9/08 at 09:11 PM |
i use the kit as supplied by aries motorsport, it works perfectly. I am planning on getting the throttle "blipper" for the blade engine,
supposed to work well according to a good friend who used to own a fireblade bike.
regards
Mark
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
rubberburner
| posted on 12/9/08 at 05:29 AM |
Im using a flatshifter on my car. Very pleased w both the performance and ease of installation. Ive got a '98 R1 engine now injected w Jenvey
throttle bodies. The "autoblipper" came with the correct threads for the throttlebodies, everything just went together very smooth and
worked straight out of the box without the need for any adjustments at all. Im very pleased.
hobbsy
| posted on 12/9/08 at 07:20 AM |
rubberburner,
Do you have any photos of your install?
Specifically how close is the autoblip unit mounted to the throttle bodies.
My Trickshifter basically uses the same kit but I think I need to adjust the shift rod sensor a little and mount the autoblip unit closer to reduce
the vacuum hose length.
Meeerrrk
| posted on 12/9/08 at 06:04 PM |
found out the throttle blipper is an add on for the powercommander unit.
regards
Mark
Jon Ison
| posted on 12/9/08 at 06:10 PM |
I have flatshifter, v happy.
rubberburner
| posted on 12/9/08 at 09:03 PM |
Pic of the autoblipper as requested
  autoblipper
[Edited on 12/9/08 by rubberburner]
It simply replaces the idle screw and there is a support at the actuator end to keep it from falling off.
hobbsy
| posted on 13/9/08 at 11:08 AM |
Hmm your vacuum pipe runs are quite long like mine.
I think I just need to adjust either the shift rod sensor or the vacuum unit itself then.
It seems to rev up a bit slowly and for possibly too long when I go for the downshift and so at the moment I've disabled it.
Its also a bit disconcerting when you're braking and shifting down and the blips kinda push you forward when you're trying to slow down.
rubberburner
| posted on 13/9/08 at 11:19 AM |
The amount of blipp is adjustable at the control unit by turning a screw there according to the manual. I didnt have any need for adjustments so I
havent touched it. My vacum lines are shortened by approx 10 cm from the delivered length.
