IDONTBELEIVEIT
| posted on 22/9/08 at 06:51 PM |
overheating rectifier
Hi all,just installed and got running my 893 fireblade engine,runs real crisp for about 10 mins,the rectifier gets really hot untouchable nearly and
the engine loses its crispness and seems to run unevenly untill i put like an office fan onto it and cool it down any suggestions????thanks in advance
wayno!!
Are We There Yet, Are We There Yet!!!!
Paul TigerB6
| posted on 22/9/08 at 06:52 PM |
Where have you got the rectifier mounted and is it on any sort of heatsink??
IDONTBELEIVEIT
| posted on 22/9/08 at 06:57 PM |
first just freestanding then mounted onto a 3mm ali plate
Paul TigerB6
| posted on 22/9/08 at 07:02 PM |
Is it sited in a position where it will get any airflow over it?? The Fireblade has a reputation for killing the standard rectifier too doesnt it.
Have you got an uprated one?? Worth a search on the subject anyway.
IDONTBELEIVEIT
| posted on 22/9/08 at 07:11 PM |
it,s on my westfield and mounts above the passenger footwell near the scuttle panel,so no to airflow,any idea what other rectifiers would be
compatible cheers paul B6
position marked with arrow!!
Paul TigerB6
| posted on 22/9/08 at 07:27 PM |
Hopefully the following thread will help. Where you have it certainly wont give any airflow so i'd imagine it will fry pretty quickly. Currently
building a car with 001Ben and we made an aluminium panel to fit down in the lower engine bay similar to Jon Ison (but we put the panel right across
the car) to hopefully give some airflow from underneath. This might be tricky for you depending on how far along you are - extending all the wires
etc??
Linky
| posted on 22/9/08 at 07:43 PM |
From my failing old memory banks... ISTR that many people with the BEC inadequate blade regulator problems made use of the Honda Superdream Regulator.
It is basically the same unit with fins... a little like Mr Isons' upgraded one.
Having said - we never had a problem with our standard 893 'blade engined regulator mounted on an aluminium plate between the rad and the
engine. Worked great....
bigpig
| posted on 22/9/08 at 08:39 PM |
Yep. IIRC its the same reg/rectum frier that Honda use on several bikes. One fix I've seen is to put a PC CPU fan on it, don't know how
long it can cope with the environment, but at a fiver a pop, if it lasts a year, its cheaper than a new unit.
I've also heard of using the super slug unit too.
A nice ally plate behind it should act as a decent heatsink, coupled with a fan should do the job.
