Author: Subject: Ignition Warning Light
Mk-Ninja
posted on 7/1/04 at 07:45 PM Reply With Quote
Has anybody put an ignition warning light on a BEC. I assume I need a supply from the ignition and one from the regulator but could do with details.
Thanks Gordon
I'm sure I've got one, just don't know where I've put it
posted on 7/1/04 at 10:15 PM Reply With Quote
wouldn't the Oil Pressure light function as an ignition light anyway?
Mk-Ninja
posted on 8/1/04 at 08:22 AM Reply With Quote
Good thinking.
Id got myself thinking that when I turned the ingition on there would be no indication, but as you point out there will.
I guess the only thing it wont do is tell you that the battery is being charged.
Gordon
posted on 8/1/04 at 10:08 AM Reply With Quote
wouldnt the battery warning light come on as well? or havent you included one?!
Mk-Ninja
posted on 8/1/04 at 10:53 AM Reply With Quote
Joel
Thats the bit that seams to be missing on bike electrics, but Ive got more than enough wires to sort out at present so I think Ill just go with the oil light for now and look at putting an ignition/charge light on in the future.
Gordon
Bob C
posted on 8/1/04 at 12:58 PM Reply With Quote
It's a fair cop Gordon - I hadn't considered that - I guess I'll need another circuit that lights something up if the battery volts is less than (say) 13V, easy enough to do, I can use the shift lights.
I was still thinking in terms of a conventional alternator...
Bob C
posted on 8/1/04 at 03:03 PM Reply With Quote
Originally posted by Mk-Ninja
Joel
Gordon
ah, i see! didnt realise it was a bike setup! a job for a rainy day mayhaps?!
oops, that today innit...
lsdweb
posted on 24/3/04 at 11:48 AM Reply With Quote
BobC
Could you give a rough idea on how you'd rig up this warning light - my knowledge of electronics is very imited. Many thanks
Wyn
Bob C
Bob C
posted on 24/3/04 at 01:12 PM Reply With Quote
Isdweb,
zener, pot, transistor, resistor and LED. Chose the transistor connection (common emitter/common base) so the temp. coeff of the zener & the transistor cancel each other out (under dash temps exceed 100c in summer) Get a mate who does electronics to work out the details & debug! I'm doing a digidash for Gordon so very easy & cheap to include as an afterthought!
Bob C
lsdweb
posted on 24/3/04 at 01:21 PM Reply With Quote
Many thanks Bob
I'll get my Idiot's Guide to Electronics book out............
