Author: Subject: Help please - what is this part from?
aka Keith
posted on 25/9/08 at 09:48 AM Reply With Quote
I was at Silverstone yesterday, and my gearlinkage broke.
My car has a zx9r engine, but on looking at the Kawasaki parts online , it does not look like a Kawasaki part (or maybe I am being thick).
I have attached (or attempted to) two pictures of the offending item, in the hope that someone recognises what it is from, so that I can get a replacement.
I has a number stamped on it: 601 268 1130
Craig
Mr Whippy
posted on 25/9/08 at 10:07 AM Reply With Quote
Just looks like a sports bike remote shifter lever, bet most Kawasaki ones would fit, probably better with a steel one though unless you fit travel limit stops
gear change back view
gear change front view
[Edited on 25/9/08 by Mr Whippy]
INDY BIRD
posted on 25/9/08 at 10:18 AM Reply With Quote
Hi This looks like the gear leaver that attaches to the spline comming out of the engine from gearbox,
Would be used to change gear with your foot normally.
You could try ebay or
Mk will make one with just a spline and a straight bit of metal comming off it so you can shape it and cut to you length,
Hope this helps and if im wrong im dur some one will post here.
Sean
aka Keith
posted on 25/9/08 at 10:19 AM Reply With Quote
Thats the thing Mr Whippy,
I have tried to search the Kawasaki parts system, by the number stamped on it, but get no results.
I have also started to look at each Kawasaki bike individually to see if is from that specific bike, but it is a long slog.
It would be really great if someone reconizes it can and name the part/bike it is from.
Craig
r1_pete
posted on 25/9/08 at 10:23 AM Reply With Quote
Its part of the gear linkage, the bit which fits on the splined output shaft from the gearbox, on the bike its connected by an adjustable rod to the gear lever. I'd guess on the car its either solenoid controlled (paddles) or connected to a set of linkages to the gear lever in the car.
Try THIS
[Edited on 25/9/08 by r1_pete]
aka Keith
posted on 25/9/08 at 10:26 AM Reply With Quote
Sorry folks, I now understand what the part does.
The biq question I have now is what did it come from originally, it is not from a zx9r, so where do I get its direct replacement?
Craig
adithorp
posted on 25/9/08 at 10:27 AM Reply With Quote
Think most bikes have the same spline size so it might not be from a Kawasaki. Could just be a convienient size one from something else that was used?
adrian
http://jpsc.org.uk/forum/
wilkingj
posted on 25/9/08 at 10:40 AM Reply With Quote
Why not ally weld it, or even use one of those Low temp ally welding processes, like the foreign chap always demo'ing it at the rally's.
Or Technoweld (Ive used this and its pretty good).
No one will see it if the result is not pretty.
Just a thought.
Best Regards
Geoff
http://www.v8viento.co.uk
aka Keith
posted on 25/9/08 at 10:44 AM Reply With Quote
Unfortunately, welding it back up, or other technique, is not really an option, as the splines have been worn away. Hence the need for a new version.
Craig
[edit for spelling]
[Edited on 25/9/08 by aka Keith]
r1_pete
posted on 25/9/08 at 12:29 PM Reply With Quote
I recon an ebay search in motorcycle parts for Gear Linkage, is the best bet, hopefully you'll find one that looks the same, or near enough to be modified to fit.
Perhaps ebays only remaining redeeming feature, most sellers display pictures.....
posted on 25/9/08 at 01:15 PM Reply With Quote
This is from Bike Bandit for the ZX9R.
Isn't it the crank at the end of the shift mechanism?
aka Keith
posted on 25/9/08 at 01:22 PM Reply With Quote
Ben B, if you mean part number 13236A in the diagram you posted, I do not believe so.
13236A does not have the splined hole at the end.
The bit in question, is more like an elongated part no. 13242 without the rose joint.
I have been loking at ebay for hours now, still no luck
smart51
posted on 25/9/08 at 01:38 PM Reply With Quote
When I saw the part yesterday I thought it looked quite long. Much longer than the Yamaha arm. I put it down to being a Kawazaki. Perhaps it is from something different.
Do you still have the phone number of the guy who built the car?
aka Keith
posted on 25/9/08 at 01:47 PM Reply With Quote
Colin, I pinged Austen a U2U last night, and he pingmed me back a note to say he thought it was a Kawasaki part.
If it is, I cannot seem to find it for love nor money.
You can see the part in the April edition of his build site http://www.greatplains.co.za/mk9r/index.html
But I cannot seem to find a direct replacement
smart51
posted on 25/9/08 at 02:37 PM Reply With Quote
What I would do is take it off, clean it a bit and go down to my nearest main dealer saying "can I have another one please". Let them earn their money by looking it up for you.
Does it have a part number and manufacturer's name on it?
aka Keith
posted on 25/9/08 at 02:50 PM Reply With Quote
Colin, it has a part number on it.
601 268 1130 and what looks like a tiny mercedes benz logo on it, which I find very confusing.
cheers
Craig
t.j.
posted on 25/9/08 at 06:37 PM Reply With Quote
hmmmm.
The 601 is a engine series from Mercedes. Maybe a engine part? Belt or pump?
Or is it a window lever or part from gear-box?
[Edited on 25/9/08 by t.j.]
smart51
posted on 25/9/08 at 09:29 PM Reply With Quote
The arm was splined and was the right diameter but much longer than a bike shift arm. Perhaps it is a part from a merc. You could ring a local dealer and quote the part number. Their computer might find it for you.
aka Keith
posted on 26/9/08 at 08:05 AM Reply With Quote
The RAC and I phone a merc place the other day, no luck with it, - they could not find the part. but I may try another dealer.
I looked online yesterday at Merc parts, and used the part number but no luck there, either - hay ho, the search continues.
Craig
[Edited on 26/9/08 by aka Keith]
