Author: Subject: help blade electric question
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
Building: built mk indy blade now got a cobra
posted on 1/10/08 at 07:49 PM Reply With Quote
hi there
i have started to wire up the engine i am using a sierra ignition barrel a savage start switch which i have wired up ok
just one question what happens to the stop switch wire on the blade loom ?
thanks stu
marmot0
posted on 1/10/08 at 07:58 PM Reply With Quote
on the 954 the ignition switch, engine stop switch and starter button are wired in series. you can hid the stop switch under dash as a security measure
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
posted on 1/10/08 at 08:37 PM Reply With Quote
ok cheers that makes sense what sort of switch did you use
stu
marmot0
posted on 1/10/08 at 08:40 PM Reply With Quote
Just used a toggle switch, needs to be rated around 10 amp
