Author: Subject: camber,toe in how many degrees???
IDONTBELEIVEIT
posted on 5/10/08 at 05:54 PM Reply With Quote
as above really,running a westy megablade with 893cc engine,what degree of camber (front,rear) are you guys running also how much toe in
wayno
Are We There Yet, Are We There Yet!!!!
mark chandler
posted on 5/10/08 at 09:26 PM Reply With Quote
1/2 degree toe in, 1/2 degree camber on both ends on my homebrew.
rgds Mark
IDONTBELEIVEIT
posted on 6/10/08 at 05:41 PM Reply With Quote
cheers mark,is the 1/2 degree toe in each wheel or combined regards wayne!!
mark chandler
posted on 6/10/08 at 09:53 PM Reply With Quote
Each wheel
For toe in I used a lazer level pointed at a board 10' in front of the car and a decent spirit level for camber.
As its a BEC corner weights using bathroom scales, you need really level ground for this.
I,m not saying this is correct, my car has rubber bushes inboard. The Westfield site used to have a table of suggested values.
Regards Mark
Antnicuk
posted on 9/11/08 at 04:36 AM Reply With Quote
can you give a brief explanantion of how you did the toe?
cheers
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
adithorp
posted on 9/11/08 at 01:15 PM Reply With Quote
Toe-in should be quoted as the combined angle.
adrian
http://jpsc.org.uk/forum/
IDONTBELEIVEIT
posted on 9/11/08 at 03:45 PM Reply With Quote
I drew up a plan view of the car in Autocad then set the wheels @ 1/2 degree combined then drew a line from outside edge of wheels,on the car then pulled a length of 60lb braid along the outside edge of wheels centralised them by measurement, then measured the distance from rim to braid(strong fishing line) be interesting to see how close i am when i finally get it set up professionally
