scotlad
posted on 11/1/04 at 03:24 PM |
carb fuel return line
Hi folks.
will it be ok to block off the fuel return line thats supposed to go from the carbs on my fireblade engine
back to the tank???
alister667
posted on 11/1/04 at 06:09 PM |
What year is the engine?
[Edited on 11/1/04 by alister667]
scotlad
posted on 12/1/04 at 06:56 AM |
1993 or thereabouts
ChrisGamlin
posted on 12/1/04 at 10:42 AM |
There isnt a return pipe on the blade carbs, you should however have two fuel inlet connections, one for each pair of carbs. The other thing you may
be mistaking return pipes for is the breathers, which obviously can't be blocked!
Chris
scotlad
posted on 12/1/04 at 03:32 PM |
aaah right- shall check again when the rain stops! still waiting on council for building warrant to build the garage!
