mads
| posted on 21/10/08 at 12:43 PM |
fuel and brake line routes
Hi all,
Have done a quick search but couldnt find an answer in previous threads.
Does anyone have any recommendations on the best route to run the fuel lines?
And any particular type/size of fuel lines I should use? Link to supplier too if poss.
And do I need to protect the pipes with anything to stop vibrations causing them to crack/split?
Same question but for the brake pipes please.
Details of car:
MK Indy R
'08 R1 engine
Discs all round
LSD
A diagram would be fantastic if possible please.
cheers.
[Edited on 21/10/08 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
speedyxjs
| posted on 21/10/08 at 12:56 PM |
I beleive the brake and fuel lines can be routed on the same side of the tranny tunnel but the fuel line CANNOT be run next to the wiring loom.
Rob WM
| posted on 21/10/08 at 01:08 PM |
I installed the brakes as per MK and have installed the fuel lines so far. I am currently completing the wiring but can e-mail you my build diary to
date which should give you some idea. U2U me your e-mail address and I will try and get it to you today.
