Andy W
| posted on 17/1/04 at 07:29 PM |
ZX9 cat
Just wondered if anyone know's the price of an end can with a cat built in it. I've been quoted £100 to hire one for five days, as
I'll probably need it twice £200 seems quite expensive. Better still has anyone got a zx9 through the emmisions any easier and cheaper.
Cheers Andy
Wadders
| posted on 17/1/04 at 08:27 PM |
Tiger do a cat for £105+vat. the full closed loop lambda system is £300ish.
i had to disable this to pass emmisions, so if your lucky you will pass with cat only.
Cheers Andy
benedict
| posted on 19/1/04 at 08:59 PM |
If you're saying that you'll need it twice as you expect to fail sva, bear in mind that most (ok not 100.0%) sva faliures are fairly
easily remedied. You can usually get a retest in within afew days as it's often only 5-10 mins just to check the faliure points.
Ben
Andy W
| posted on 20/1/04 at 11:13 PM |
Thanks for the info, just thought i'd better budget for two go's though. The cat from tiger sounds ok, if it will get mw through S.V.A. ,
My mate's building an M.K. with a blade engine so we may share the cost.
Jim
| posted on 21/1/04 at 08:02 AM |
On the second test I thought they only tested for the failure points from the first test. On my MK Blade I failed on emissions the first time and
several other minor things. The brakes past first time and they did not check them again
Jim
