Author: Subject: Found an engine
mookaloid
posted on 3/11/08 at 08:59 PM Reply With Quote
Found an engine
Ok engine now secured
Carbed Blackbird
Anyone know where I should get a sprocket adapter from?
Any other hints or tips greatly appreciated
Mark
pif
posted on 3/11/08 at 09:03 PM Reply With Quote
got my sprocket from MK for mine.
best money i spent on my carb b'bird was a trip to bogg brothers for a carb set up session.
been a bit of a rush job really, bodged it all together in just 5 1/2 years.
IDONTBELEIVEIT
posted on 3/11/08 at 09:06 PM Reply With Quote
try here mookaloid
heres my homemade blackbird cradle if you want anything cutting
Are We There Yet, Are We There Yet!!!!
mookaloid
posted on 3/11/08 at 10:29 PM Reply With Quote
That looks very smart Wayno
Have either of you guys dry sumped the motor?
Mark
MydT9
posted on 4/11/08 at 08:17 PM Reply With Quote
Carbed Blackbird
Mark
I run a BB in my Darrian rallycar, i usually run around 1/2 litre of oil above full mark to compensate my use of the standard sump. Main bearing number 3 likes plenty of oil and is usually the first area to start screaming at you if starved.
Try and achieve around 60lbs of oil pressure at 3,000 rpm (when engine is warm) which is a good indicator of sound oil pressure.
I personally run the Silkolene 10w 40 fully race synthetic and never had a problem.
I used to use Honda Fireblade clutch springs but have now gone to a drag bike competition spring set and never missed a beat. Use genuine Honda clutch plates as the after market cheap ones are not worth the hype imho.
Standard Honda spark plugs are fine.
Oh, and wiring it up to start is a total doddle If you need info, pm me
Good luck !
Mydrian
Myd
http://uk.youtube.com/watch?v=RPWhhbaPG4o
INDY BIRD
posted on 5/11/08 at 10:44 AM Reply With Quote
Hi
In my previous blackbird car i also ran about 10% extra oil with an accusump had no problems,
Tha standard sump was shortened by mk and even on hard bends oil pressure didnt drop below 20 psi,
INDY BIRD
posted on 6/11/08 at 12:15 PM Reply With Quote
Another pic on zx12r engine,
as described ran through bulk head to manual valve to turn on an off
thanks
