I'm still on the lookout for a decent donor but was just wondering about the above - if I pick up a donor with power steering, does it really
matter? I'd have thought it would be as simple as just dropping the power steering pump and any other associated bits out of the steering system?
Or do racks with PAS have issues when they're left un-powered...
Also, with the abs - what's the crack with that? I know it would be ridiculous to have abs on such a light vehicle so is it possible to adapt an
ABS system to become non-ABS?
No you can’t use the ABS components as non ABS
The power steering rack won’t normally fit in a 7 unmodified as it will be to wide so you’ll need another rack plus the MOT/SVA guy will be less than
impressed if you fit one and not even have it connected to a pump as it might seize in the future also the steering wheel will be almost imposable to
turn as the gearing is totally different
the ABS will mean that you should have rear discs and the larger fronts (260mm discs with bigger calipers)
that shouldn't be a problem, but you'll have to pick an aproprite size of master cylinder (/cylinders + a balance bar)
and you could always get a rack from somewhere else....
My donor had abs fitted and i did not use the abs part and i used a master cylinder off a non abs car you don't need a balance bar
obviously I was referring to the ABS master cylinder...
cheers for the replies guys - im still learning which bits will match with which other bits, and what will work with or without the said bits....
and thanks mookaloid, you'll have to pop down soon - welder tomorrow
..... the steering wheel will be almost imposable to turn as the gearing is totally different
so am i right in assuming that the only real difference between an abs and non abs system is the master cylinder? i.e. the abs has some kind of pump
to pulse the pressure when the wheels lock?
If so, is it as simple as mentioned above - just swap mastyer cylinder for a non abs and job done? thanks again
I'm building a locost based on an mx-5, planning on using the power steering rack off that but without the pump attatched.
Why would sva have a problem with this?
No more likely to go wrong than a normal non-power steering rack and it gives a ratio of 2.8 turns lock to lock so won't be too heavy at all in a
7. Its also narrow enough for the wishbone lengths I'm using so bump steer isn't an issue...
I too am using the calipers from an ABS car but a non ABS master cylinder.
This replaces the ABS cylinder and distribtion box thingy (not sure what its called but had 4 pipes coming out 1 to each wheel)
On the Power steering rack side The rack will be hard to turn as it is a 2.5 turns lock to lock ratio and if you are going to use it you ned to leave
some fluid in it for lubrication and link the ends out. I couldnt use it because physically it is different where the column connects.
It is taller because of the valve and it would have fouled on things.
In addition you will have to cut the mounting for the pump off the distributor bracket as it will most likely be right where the column extension
needs to pass.
Been there done that fitted manual rack acquired from local scrap yard
Thanks for all the replies everyone!
It just means I'll ignore any donors with both PAS and ABS (unless they're absoutely mint and for free), and instead, keep my eyes open for
a non pas/non abs example.
I'm going to wait until the chassis is nearly done and then start looking for a donor I think - money is too tight to buy the steel and a cahssis
at the same time atm. Thanks for all the help!
I wouldnt dismiss them out of hand. Just bear in mind you'll need a non ABS master cylinder and a non PAS steering rack when considering them
pricing wise also.
In addition if you get on to the Ford sierra owners club Forum you can sell the bits you dont want.
My donor currently stands at a nett cost of £25 after selling bits and I didnt sell everything I could cos I wasnt exactly delicate stripping it
out
[Edited on 17/12/08 by Vindi_andy]
