I am hoping to use a capri or cortina as the donor and wish to buy a +4 chassis.
does anybody know of any suppliers?
Any body got any advive about my choice of donor
if you have a cortina in your sights snap it up, its a perfect doner........
I have used a capri axle, it fits nicely into a book chassis, a few minor modifications.
You are still going to need cortina uprights, unless you use sierra ones with suitable adaptors, in which cas why not use a sierra donor and a GTS
dedion rear end for a simple, quick build. They also do the complete chassis
thanks for the help. i will try and get hold of a cortina. can anybody suggest what the best MK or model of engine would make life easier for me
i presume MK as in mark, not MK as in MK engineering ?
MK 4s can still be found, engine, box, back axle, front uprights, + lots more will all be usefull,
guess 2ltr pinto is the one to find, 1600 ok though.
Now if it was MK as in MK engineering go find your self a old jelly mould sierra........
confused ? you will be..........
As John said, if you are going for MK, a sierra is in order, if building your own chassis, a cortina would be ideal, but parts are becoming more
difficult to source.
Sierra parts are available everywhere, and your choice of off the peg chassis is much greater. If I was starting again I would buy the most
comprehensive kit I could afford and by now I would be preparing for my next MOT, not starting to prepare my chassis for its final paint
