hello, just wondering its possible to get a sierra 2l dohc into a mk or gts jobbe??
cheers
Yes but don't unless you really need to! Pinto is much better option out of the two if budget build. DOHC is not well liked by aftermarket tuners so parts are in short supply, Pinto parts are cheap and easy to source and power is about the same. If your donor has a DOHC don't worry as you can still use the gearbox and other parts as Pinto will mate with Type 9 or MT75 gearbox. If you really must have DOHC go for either zetec/vauxhall XE but cost must be taken into account.
I know the DOHC is not liked, but if it fits it has 125bhp without tuning so for true locost, and less work, it gives more power than any standard
pinto.
I'm going to use mine until it breaks or I get something else cheaply which gives more power.
The timing chains are renowned for breaking, but only if not correctly serviced, probably worth changing, easy to change, just line up the gold links
Have a look at the Robin Hood advert in this months kit car mag. It has a bit about the dohc version of the Robin Hood 2b. You will see the additional costs and the reasons given..... Stick to the Pinto if you can, Your pocket will love you for it.
i'm putting the dohc engine into my locost
but i got a slight twist for mine - its; the rs2000 flavoured one (same bottom end, but 16v head as
opposed to 8v dohc head) with a big hairyarsed turbocharger sat on the side for good measure
dont ya just love making things complicated
lol
[Edited on 24/2/04 by Graceland]
with a big hairyarsed turbocharger sat on the side for good measure![]()
theres the turbo technics conversion avalable which would give you approx 170bhp to 180bhp at 6psi of boost for the dohc, but they are so rare and
change hands at upto 1k for the kit alone
i made my own manifold for the exhaust when i did mine tho and my own management and it worked really
well
stick a post on www.interford.co.uk sa theres a few people on there with dohc turbo xr4x4's
so i wanna get a 2 litre pinto, so does that mean any sierra bfore the year 1991 will pretty much do, even a sapphire? as u can tell, not much of a clue about exactly what to go for....
dohc will be easily recognisable, will have a wider rocker cover etc. sapphire is no different from the others really. quick scan of ebay will find
loads, usually still running and maybe, just maybe, local.
DOHC's are taller also-may be clearance problems??
i have got a dohc on my garage floor
the problems i hade in trying to use it were as follows
its to tall
the sparks are controlled by the ecu
the injection manifold sits up four inches above the rocker cover
parts cost a fortune
exhaust manifolds are nowere to be seen
same for twin webbers
all these problems can be overcome but because of the cost and extra agro i bought a 2ltr pinto for £50 and its saved a small fortune
ps if anyone wants the dohc engine they can have it free
cheers dave blissett
this is why i am using the rs2000 16v engine (same bottom end as sierra dohc) - my custom inlet and exhaust dont sit higher than the cam cover and the
cam cover sits 1/2" lower than the sierra dohc one
If you look in the web for australian builders you will find that they use extensively Toyota DOHC engines 16 and 20 valve ones in 1.6 and 2.0 liter
sizes they have even recomendation about transmissions to be used, etc.
SACEM1
Don't forget to inspect the teeth on the sprockets. If they are worn or hooked they will need replacing as well and they are not cheap. Bro in law's new chain failed within 6 months because of this and cost him dear.
On the DOHC, you cannot get a chain without the sprockets, and only available from Ford. Bit like bikes, always replace as a set
ok i am thinking that a 2l pinto with some webers or del ortos could b the way forward. BUT what about an injected pinto (is there such a thing?!) in terms of reliability and price, and availability. I have been scouring second hand sierras, and a great deal of c. 1990 models re injected. any pointers?
i would re-iterate the points on bike engines. looking back, i just cant see why i didnt pick one when i started. Just scared of complexity i
guess...
turns out its not complex anyway!
out of interest Joel, what are you building? and I see you are in Leeds, where abouts?, as I am in Skipton.
north leeds, on the ring road just about. Alwoodley. im doing a vaguely 7 based thing to my own design, with sierra bits throughout. Main aim is to
finish it and keep gaining experience, so that i can get cracking on a planned twin bike engined middy one day!
are you just starting, started or plotting still?!
plotting at the moment, trying to get round a minor problem of no garage at the moment!! I would like a screaming road rocket with a BE, but as you say it scares me a little... It would seem simpler just to use one sierra donor... still to make my mind up... also the cost of a blade is pretty steep compared to a car engine
all true as you say, whats really bugging me is the effort i've put into making an exhaust manifold for a crap 1.6 engine!
still, all in the
name of experience...
