Hi Guys,
I've been offered a transit van as a donor, really cheap, is it feasible?
It is a 1990 G reg mk3 with a 2 litre pinto petrol engine and a live axle rear end. Looks like it should work....
Alex.
no reason why not! what gearbox has it got? and the ratio of the diff?
it might be geared differently to a sierra or capri for example, but its definitely possible
mate you should have a good pinto there,you will need to change the cam and flywheel,
also good if you want to turbo it as it will be low cr
How much does a transit rear axle weigh?
Originally posted by matt_claydon
So not really a very good Pinto then
But if its got twin rear wheels would be good for traction.
Paul
How much does a transit rear axle weigh?![]()
Isn't it going to have a 5 stud wheel pattern at the rear?
What will you fit at the front that will match?
I don't know, but I'd be surprised if the rear axle wasn't a load wider than an Escort or Cortina.
People give Pintos away now, it's hardly worth the hassle I'd have though.
James
Paul
get the transit for free...
then sell it for spares or repairs probably get £200 and put this towards sierra donor!!!
Paul
A 6 wheeled locost!!!![]()
Am i right in thinking that a transit pinto is taller than a sierra pinto? (not sure where i recall that from)
I was also thinking the axle would be very wide.
Well, I can measure the width of the transit axle, but how wide is an escort axle for comparison?
Alex.
Alex.
Alex.
I say do it, you can always change the rear axles and hubs can't you?
I suppose it depends how much the transit is
