So I've got a nice new standard (non-ABS) master cylinder for a Sierra. I know that the two connections on the side go to the front and rear
braking circuits but there's also a connection at the far end (as viewed by the driver) on the underside. Does anyone know what this is for?
Thanks Alex
the two front ones go to the front brakes, and the rear one goes to the back, then splits with a t piece.
There should be 2 connections for the split circuit front brakes [one to each caliper] and one for the single circuit rear.
Stu
Thanks - makes sense now.
