It's a long story but last weekend bleed the brakes and notice a slight movement in the ma ter cylinder bulkhead even though it is 1/8 plate!
So i need to weld in some supports either side of the brake master cylinder. no probs except..
i can't reach 'cos the steering wheel in the way
how do you remove the steering wheel sierra centre horn??
prise it out with a flat bladed screwdriver, undo the nut or bolt. Then pull like billyo you may need to give it a bit of a bash from underneath
do you mean prise out the horn?
yea prise out the horn its a push in fit
always one spoil sport, I was waiting for the ooooh Ive smacked myself in the nose kinda moments
so let get this right
1 prise out the horn with flat blade screwdiver
2 wipe blood off nose wth oily rag
3 undo centre bolt
4 pull off steering wheel
5 wipe nose with oily/bloody rag
Pulling the wheel off will twit into your face...you're safe from the horn push unless you point the screwdriver towards yourself slip and then
twit yourself with the end of the screwdriver!
so
2 undo centre bolt
3 pull off steering wheel
4 wipe nose with bloody rag
Originally posted by plantman
so
2 undo centre bolt
