hi everyone ive just bought a locost chassis will i be able to use a vw 2.0 gti engine? thanks
Welcome.
I dont know, but someone here Will.
Quite a tall engine the 2.0 Gti.....
Although nothing is impossible in KC world I'm sure there's many easier candidates to choose from? Then the conversion to RWD when many
Fords are easier using common components.
It's also not a particularly fast or sporty engine either.
thank for that i think ill stick with ford parts,cheers
one more think guys does the haynes book worth it to start building the car or should i look for a work shop manual? cheers
I would think you need all the information you can get so buy the Haynes manual, a workshop manual which covers your running gear and anything else
you can lay your hands on to start with
Mooky
thanks mate
Hi
this is the company you want VAG ENGINE IN A 7
hth
Eh! Which GTi are we talking about?
