Hi all
I have changed my drums for discs and have been told to use escort front discs, I have the sierra callipers but dont know what year escort or cc to
tell the motor factors ?? any help appreciated cheers
Rob
mk3 front non-ventilated Escort
or
mk3 front fiesta, non-ventilated
Both at 240mm diameter
Both require the hub machining down
the offset is different (escort is larger).
http://www.brakesint.co.uk/ has pictures of all of these.
I have a pair of mk3 escort disks that I just removed and have very little wear. I also have similar Sierra disks. Too expensive to post, but if you
are local you can have either pair for £5.
Matt
Cheers for the offer but i am down in worthing bit too far to travel , thanks for the advise.
