Recently bought a part finished project, which is undergoing a compelte strip and rebuild to MSA specs, and an engine change.
Just after some help identifying what donor car it's been built around.
It has a 1.8 xflow with type9 and live rear (Don't know differences between "english" or "9 inch" etc)
What identifying parts will help pin down what car these parts came from?
Live rear English the diff comes out the casing as one solid unit from the front face. Atlas axle diff has thin plate over diff internals on the rear
of the casing and they are usually of the wider type 52" flange to flange.
Hope this helps, If you post pictures I'm sure it would help identify correctly
RD
Originally posted by speedstar
It has a 1.8 xflow
The best thing to do would be to post some pictures up here so that the knowledgeable peeps on here can tell you what you want to know.
A picture paints a thousand words so stick some up. I can pretty much gaurantee you it WILL NOT be a 1.8 crossflow I think the most you can get from a xflow is 1750.
1.8 cvh? agree with the picture thing.
Rich
I'll get some better photos ASAP but its this one...
http://www.locostbuilders.co.uk/viewthread.php?tid=151562
Also, 1.6 XFlow. My mistake!
need some photos and then can help
