I was wondering if anyone could tell me how to identify a 1300 x flow engine. My mate has an escort engine that he wants to get rid of but i want to check it is a 1300 gt before i buy as eventually i might try to enter the car in the 750 mc championship. Any help would be mint. cheers
All 1300 xflows had the 711M6015AA engine number, I think what made it a GT was the cam (which would need changing for the 750MC Locost regulation
one) and the twin choke carb and the 4 branch exhaust manifold.
I'm building a new engine for my race car from a standard 1300 xflow, as I already have the correct carb there's nothing GT specific that I
need.
Shaun.
Pistons are definately different, GT has valve cut outs and compression ratio is 9.2:1 for GT and 9:1 for STD and 8:1 for low comp eng if you beleave
the Haynes Manual for
MK 1 Escort. I know that Haynes manuals are not allways correct but I beleave they were more acurate in that era and I have pulled a few of them
apart.
The GT head also has different inlet valve sizes and lengths, inlet valve dia 38.02-38.82mm GT, 35.69-35.94mm STD.
[Edited on 17/5/11 by spiderman]
It is the 1100 and 1300 that are difficult to tell apart.
Originally posted by ShaunB
All 1300 xflows had the 711M6015AA engine number, I think what made it a GT was the cam (which would need changing for the 750MC Locost regulation one) and the twin choke carb and the 4 branch exhaust manifold.
I'm building a new engine for my race car from a standard 1300 xflow, as I already have the correct carb there's nothing GT specific that I need.
Shaun.
When you say standard engine what are you thinking? You need to take a look at the
Locost Regulations to fully understand what needs to be done to make an
engine legal for the series.
The block will need to be bored +90 to accept either of the mandated pistons (so having GT pistons is irrevelant). The cam must be the regulated one
from Kent. The flywheel + clutch will need to be lightened anyway, a GT flywheel just gives you less to remove. There is no difference in valve
sizes on 1300 heads.
The Weber twin choke carb from the GT is needed, but can be picked up seperately, same for the inlet manifold. Exhaust is free and I've seen
no-one running a standard GT exhaust manifold, probably too restrictive.
I picked up a standard 1300 xflow for £25 off eBay, a set of pistons from a fellow LB'r and a cam kit from Kent. A local company are doing the
machining work for me, I'm doing all the building up.
Shaun.
quote:I have a Mk2 Haynes manual and it just gives a single size for 1300 valves, 38.02-38.28mm inlet, 31.34-31.59mm exhaust, this ties up with what my standard head had fitted.
Originally posted by spiderman
Pistons are definately different, GT has valve cut outs and compression ratio is 9.2:1 for GT and 9:1 for STD and 8:1 for low comp eng if you beleave the Haynes Manual for
MK 1 Escort. I know that Haynes manuals are not allways correct but I beleave they were more acurate in that era and I have pulled a few of them apart.
