Will the drivetrain from the MX5 fit into the stock haynes roadster chassis?
vanepico - 24/9/11 at 04:15 PM
Name says it all really, what modification, if any, is required to fit it? I was thinking if I could still use all the standard wishbones and stuff, I'd hate to finish building it then get a donor and it not fit
Thanks, Pete
carlknight1982 - 24/9/11 at 04:22 PM
Nope, but google Saturn sports cars they sell everything you need. And if u want to see a complete ford based roadster your welcome to pop over and take a butchers at mine
vanepico - 24/9/11 at 04:44 PM
they sell the chassis parts, and it gives you the option of type 9 or MT-75 :s
Tatey - 24/9/11 at 04:50 PM
http://www.saturnsportscars.co.uk/mx5.php
vanepico - 25/9/11 at 09:52 PM
Do you know if the mx5 flatpack set comes with the brackets for the wishbones and shocks?
JAG - 25/9/11 at 10:46 PM
The engine and gearbox from a 1994 Mazda MX5/Eunos are fitted in my Stuart Taylor Locost.
Check out my photo' archive. I shortened the sump and cut some mounting points off the tail of the gearbox otherwise it fitted - JUST.
vanepico - 15/10/11 at 08:53 AM
im wondering whether it is worth getting the mx5 chassis set because they are charging quite a lot for the matching wishbone set :s
