So far, I've had no problems finding sources for the parts I need to restore the MX-5 bits going into my Vortx. However, the dust caps (Mazda
Part B455-26-071) that prevent dust ingress into the hub nut and wheel bearing are proving very tricky to find in the UK. Any ideas where I might find
these?
Thanks in advance.
autolink?
Originally posted by prawnabie
autolink?
Hmm, this post made me think about my donor... I didn't have dust caps on any of the hubs!!
try living 3000.co.uk says theres some on there ?
There was some in the bearing kit I bought for my mx5. If you are replacing the bearings then buy a bearing kit rather than just the bearing. Failing that, ring mx5 parts. Good to deal with and very knowledgable from my dealings with them. In fact, I know I have a bearing in my garage but unsure if it's a kit or not.
Are these the ones?
http://www.mx5parts.co.uk/front-cover-mk1-25-p-1885.html
Originally posted by Adamirish
Are these the ones?
Are these the ones?
Top of the class. How I missed those is beyond me. Thank you very much indeed![]()
